Why is my jambox not charging
Brought a new battery still wont charge stays on 10% charger is good tried USB charging still nothing any help or point in the right direction would be much appreciated.
Oh and I cant use buttons while connnected to Bluetooth but i can use buttons while using auxiliary when connected to charger dunno if that means anything?
Yeh I’ve got a UE as well but I think the jambox better louder an bass
Which one? The Boom2 or Mega Boom. Size does matter ;-}
The metal bar inside the charger hole in the box is bent upwards. This is a common issue. Unplug the mini power jack (the thing with the cord)Look inside the charger hole on the jambox and take a knife to bend the tab back towards the middle or even lower. Be careful when you replug the power into the socket. The socket tab and the mini plug MUST MEET . There are male and female parts that connect. Somehow on almost all jamboxes the little tab (male part) gets bent upwards, making the connection beteen the charging cord and the charging hole impossible. Just straigthen the tab inside the jambox's mico power slot and you'll be back and running. It may take a few tries and more bending but eventually you'll get the right connection.
This isn't necessarily the solution to all problems, but it worked for me. I'd add one note - jedc and I view the micro USB slot as opposites. I consider the long side of the trapezoid to be the "bottom" and the short side to be the "top". Once I nudged the middle tab away from the long side of the trapezoid back towards the center I had a red charging light on the jambox. Thanks jdec!
Just want to say HOORAY!! I was about ready to toss the speaker and said to myself just look it up and see if anybody has any advice and THERE YOU WERE!! I bent the tab and viola... charged and working! Thank you thank you thank you!
I just replaced the battery in my Jambox and it doesn't charge. I replaced my older Jambox battery too. Neither will charge. I will check this out but they both charged fine before I replaced the batteries. Is it a problem that I used 1800mAh, 3.7V 6.6Wh Lithium-ion by EBL (for DXR-8 Video baby monitor.)It replaces Sp 803048. HELP!
Sorry to say you likely need a new logic board as I suspect you plugged in a bad or wrong USB charger which damaged the charging logic. As far as the controls this could be related.
The only problem here is Jawbone is out of business! So getting parts will be difficult! Maybe its time for a new speaker. I now have UE Boom speakers which I think offer even better fidelity than my old Jambox speakers!
Is that the top part or the board by buttons? Or near the charger?
The micro USB board is what I would start with if you can find the part. Did you get the speaker wet? If you did you might end up needing both boards.
Speaker has never been wet or dropped but partner always left it plugged in charging. I had a feeling it could be something like you said but wasn’t sure. There’s a part on ebay top board an charging board
If the USB port is damaged you don’t need a new logic board, you just need a new USB port soldered onto the board. Any good shop that deals with soldering electronics or mobile phones should be able to do it. I get alsorts to solder at work. Even down to buttons on car key boards.
I do not have an answer but in have the same problem. I only used they charger it came with. For some weird reason it is small for the opening because it is just wiggling in the charger socket. I tried some other chargers with the same USB but it did not work. I hope you find a solution
slade davis crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 113
crwdns2942667:0crwdne2942667:0 16,848
