2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
MacBook screen is flickering
I have a macbook in use at 1 year, about 3 weeks until today the screen sometimes turns white and back to normal, did not find a cause of the problem, need your help to know what may have caused this problem and
and what is a solution to this type of problem.
To better understand you can see the link below:
https://d.pr/qlicEC
I fixit it This video gonna help you fix It https://youtu.be/12dVmqLn644
Hello,
Does this only occur when you tilt and move the screen? If so, try removing the bottom panel and reseating the display connector on the logic board while checking for any dust or debris that may have worked its way into the connector. Let us know if it makes any difference.
- Jasen
it happens even when the laptop is idle on the table, is there some reason for this problem on Macbook's?
I'll try removing the bottom panel and reseating the display connector.
It might very well be a faulty cable, connecting the panel to the board. Are there any bumps on the machine body or in the plastic hinge cover pointing to an accidental damage ?
Solution would be to try a known good working screen. Unfortunately with retina screens there's not much else I could think of.
Aristides Guirrengane crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 5,259
