Startup Disk HDD not recognized... fix/alternatives?
Hi all -
I have a macbook pro 2GHz Core Duo that I recently purchased... knowing it was having trouble booting from the internal hdd. After removing the logic board, cleaning it, reseating, etc... I got it to boot up to the hard disk twice and then it went back to only booting from the optical bay or an external hdd.
I'm assuming this is a hard drive controller issue, correct? Any suggestions? I know I can remove the optical bay and install the after market hard drive bay, but if I want to keep my dvd drive, are there any fixes? I did note that all the pre-unibody macbook pro logic boards have an unused port site to the left of the optical bay but before the memory opening. Is that a potential site I could link some "X" cable to?
Thanks
PS - I tested using both another HDD and another HDD flex cable
Yes you can use the optical bay adapter: crwdns2937315:0IF107-078crwdne2937315:0
You might want to consider replacing the hard drive cable: MacBook Pro 15" (Model A1150) Hard Drive Cable
Do not use that port, it is for Apple factory testing.
crwdns2886500:0Connects hard drive, sleep light, IR sensor, and Bluetooth board to logic board.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$14.99
Hey Mayer --
It's been awhile, hope all is well. I actually tried a KG hard drive flex cable. It's definitely something related to the hardware of the board or pins on the board. Oh well... Thanks
Jason
jcarter crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 2,436
