@jojohad this was converted from an answer to a question. You need to let us know what make and model your phone is. At this time the only thing to suggests that you treat it the same way you would treat any other liquid immersion.
First you want to stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.
The very first step I would take is to disassemble your phone. After that take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. After that you clean it a couple of times in sterile water, not drinking water. Use a soft brush and clean it very, very thouroughly with the sterile water. Depenmding on the model of the phone and the amount of corrosion I envision, you will have to remove all the EMI shields. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for a Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would be great if you can get it professionally cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. Keep in mind that liquid damage is the hardest to troubleshoot and to repair.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
