Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
iPhone Stuck in White Apple Logo.
My iPhone Stuck in White Apple logo. I tried resetting the iPhone , Also Tried restoring the iPhone Multiple times even in DFU mode also. Restoration was successfully completed but device is again showing the same issue. Iphone is stuck in Apple logo itself. in iTunes device is detecting . Device is not under Apple Coverage and i believe if i visits Apple Support then they will advise for a whole unit replacement only. Kindly advise is there any solution for repairing this issue.
It seems like a bootloop.
Your iphone have problem with the new update, you can download a diffrent version of ios and downgrade it. The new update maby have a problem, and apple will fix it in time, until then you can try do plug your iphone to ituns, go to recovery and download a older version of ios. Like if you have ios 11.3 you see if you can download ios 11.1 or 11.2 and see if your problem is solved.
Will it be possible to downgrade. My IOS version is 11.2.5. Kindly advise whether i can downgrade the same?
Here you have a link to ios 11.1
Hope it work out for you!
It is not allowing to installed since the IOS is not signed by Apple. Downgrading is not happening.
You can easily try this: How to Fix iPhone Can’t Turn On & Stuck On White Apple Logo When Rebooting?
Of course this site is verified, it is free and reliable. But you may not save your date. did you backup your device on iTunes before?
HASHIR ABOOBACKER crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 1,449
