weak wifi signal and dropping
im having problems with wifi on a tab e that i have replaced the digitiser connector on, its a very weak signal around 1 bar but sometimes none and drops out. the router is about 2 metres away. another samsung tab connects fine my a3 connects fine, just a problem with this 1. it has been reset but still nothing. any ideas
can your bluetooth connect to any of the devices?
the tablet uses different antennas for pickups, but the same chipset for processing the signals. so if your bluetooth is failing as well, you will be looking at a board level issue, and if your Bluetooth works, then you have an antenna failure.
yea bluetooth is working
think i found the problem a pin has been broken off
welp, then i guess repairing that is your first step!
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Hi. Same exact thing happened to me. After replancing digitizer, Wifi got wonky. Bluetooth working fine. But I don't know where the wifi cable/flex/pins (or whatever) are so I can check . Can you show/tell me? Thank you.
There is a chance that the WiFi antenna was damaged during the replacement. The antenna is located in the top right corner of the housing, right by where a pry tool will go for removal. Try having whoever replaced your screen replace that as well, because that repair person is at fault here.
Sounds like she replaced it
daniel crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 2,310
