surface pro 3 screen replacement adhesive
I need to replace my surface pro 3 screen and would appreciate a recommendation and link to the adhesive I should use on the new screen install. Thank you
I have replaced a few Surface Pro 4 screens before and I used the adhesive best known as "red tape". It comes in all types of widths and is fairly cheap. It creates a strong bond as I have not had any complaints. You can buy something similar and maybe even stronger from iFixit linked below.
Tesa 61395 Tape
crwdns2886500:0Custom cut rolls of Tesa 61395 double-sided tape for repair.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
Tesa 61395 Tape
$8.95
What width of tape did you use? I have a surface pro 3 and I need to repair the screen and I'm assuming I could use 2 to 4 mm wide tape
crwdns2957956:0crwdnd2957956:0crwdne2957956:0 crwdns2950251:0crwdne2950251:0
I use two and double up where I need to.
3M 9448A black double coated tape. Its available from amazon. It looks like it may well be the stuff that was originally used on the surface pro. Put it on the screen edges and then VERY CAREFULLY trim the excess off the OUTER EDGE OF THE SCREEN ONLY. If you try to trim the INNER edge next to the LCD you will likely damage the digitizer connections.
Tom Swango crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 44
crwdns2959996:0crwdne2959996:0 11,218
