Guides for the LTE version of the iPad Mini 3. Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
not charging after port change
hello
i have replaced the charging port on my ipad mini 3, on inspection the port was faulty 2 pins touching, the port has been re-replaced but it wont charge, i can see a few darkened caps around the pm ic but they check out ok. please help
try a second port before moving onto possible board failures.
i have after the faulty one i have put 2 others on , no luck, now when i plug it in it connects to itunes ok but when i plug charger in it charges for a split second then stops charging (not charging next to battery)
if you have a battery on site, i would try replacing the battery next.
unfortunately the only real way to diagnose this issue is Trial and Error
If its not the charging port, try using a new charger. If that doesnt work, you may need a new battery.
Tristan chip may be the issue, can be microsolder
mo khan crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 146
