Small media streaming device that plugs directly into your TV's HDMI port. Originally released by Amazon in November 2014. The latest version comes with a voice-activated remote.
Amazon Fire Stick not powering up
What to do with an Amazon Fire Stick that will not power up?
I have a Amazon Kindle Fire, but what do you mean by 'Stick'?
The amazon fire stick is something that plugs into your TV allowing you to watch amazon prime video on it.
This is the fire TV stick: https://www.amazon.com/dp/B00ZV9RDKK?tag...
Make sure that you are using the power supply provided with your Fire TV Stick device. You can connect the included power adapter into the power port on the back of your Fire TV, then plug the other end into a power outlet.
Before I factory started my firestick it was not finding my Network or any around me. So I factory started it, and now I can't get past the setup because it's still can't find any Networks. Can somebody help me with this????
Hello! I hope you got it fixed. If not, and for others having similar issues, try this step-by-step troubleshooting guide on Firestick black screen issues. If it seems like your Firestick isn't powering on AT ALL, then you can also try this Firestick won't turn on troubleshooting guide.
In those articles are troubleshooting steps like these:
10 Most Common Reasons Why Firestick Won’t Turn On
  1. Loose connections
  2. Faulty charging port
  3. Outdated software
  4. Internet connectivity issues
  5. Insufficient power supply
  6. Compatibility issues
  7. Power failure
  8. Broken USB connection
  9. Glitch on your smart TV or Firestick device
  10. Corrupted memory/cache
Good luck!
Jason White crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 21,440
