Disassemble TV Image problem
A TV image is clear and becomes distorted The capacitors look intact And also sound electronic boards
Mise à jour (06/02/2018)
board t-con Sounds good As well cables ribbon
where is the problem
Update (02/08/2018)
liquid in that arrow
I thought it existed from a factory
Shall I wipe it?
@medjdoub45,
If your television has image distortion issues, see the Insignia NS-24ER310NA17 Has Image Distortion problem page for possible causes and solutions.
Your images a bit fuzzy but it appears that this is happening to the right half of your screen. That could an issue with your t-com board or your panel. The t-con board is the one under the metal cover that has the two cables going to the panel.
Update (02/08/2018)
Your last posted image does not look like liquid but it looks like an overheated IC. Replace the T-con board and re-evaluate.
Looks like it's not an board t con
@medjdoub45 did you try a new board?
medjdoub guerine crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 251
