ok so… there is a kill switch relay on the powerboard,almost the first component in the circuit. it will look like a small black or /blue , somtimes yellow rectangular box. it wiill have 6-8 pins soldering it too board.
almost every time. i fix a tv that does it. of coarse. whatever diode down the line burned out allow and is allowing high volt spikes when relays flip. is still burned out thus thee relay coil will also burn out eventually. unless u add a high efficent diode between switch outlet and and un switched oulet pole. poles ——->--arrow facing toward switched. this will atlt least protect from the “main” high voltage spike.
they do make relays with diode built in. but i like to build my own relays. so they work forever….. also use a heatsink between solder connection and diode or u will pop it. (make it not have direction). well love,hugs, and happy mucking.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
crwdns2944067:07crwdne2944067:0
Also when I power on the TV, a light flashes across the screen then goes black. With just a really faint tint of picture or menu on the screen. Can only be seen when you're holding a flash light up to the screen. Sound works perfectly to what ever input you select.
crwdns2934271:0crwdnd2934271:0 Sandy crwdne2934271:0
I can’t see picture what do I do to fix it
crwdns2934271:0crwdnd2934271:0 Justin b hopkins crwdne2934271:0
Mine started backlight problems, I don't know if this is only happens to LG digital set. Please how can I fix.
crwdns2934271:0crwdnd2934271:0 John crwdne2934271:0
I don't know if this is the reason but I suffer from the same problem but I believe that the TV isn't getting enough power from the cable you plug into the outlet
I Feel That's The Problem
crwdns2934271:0crwdnd2934271:0 Amani crwdne2934271:0
Hi there if got a aim TV also if I hold my torch can see the picture settings I've done scan reset it all of that it work yesterday but when I turn it on today got little picture of i put my flash light
crwdns2934271:0crwdnd2934271:0 Shaun Buys crwdne2934271:0
crwdns2934275:02crwdne2934275:0
