The Pebble 2 is a smartwatch released by Pebble Technology Corp. in September of 2016, and is a revamped version of the original Pebble Watch.
Is there any replacement for the button covers?
I just had the lower right button cover crack and fall off. Does anybody know of any ways to get a replacement rubber panel?
Has anybody taken the watch apart to see if it's even possible to do this sort of replacement?
crwdns2889612:0crwdne2889612:0 9
this should help you somehow https://www.thingiverse.com/thing:259955...
Thanks, Those shapeways links were useful. It took a bit of hand fitting, but those button panels work and now my favorite watch is running again after being idle for far too long.
I know the original question is an old one, but since a lot of pebble 2s eventually have this problem, here’s a link to my 3D buttons and cases on Shapeways.
https://www.shapeways.com/shops/astosia?...
Update, if Shapeways’ postage is too high, you can buy buttons from the website now too.
https://favouritehumandesign.com
I had the same problem und found this site, with printable 3D Models:
https://www.shapeways.com/product/UAMY5G...
Requires OG Pebble parts, but this may be a good fix.
Update (07/06/2021)
I found this just now, I have two P2HRs that both need new buttons, but I think this may be an easier fix. https://tinyurl.com/k8a5h6na UPDATE (08/05/2021) I bought the version with the battery and glue. It’s a fairly easy transfer. Requires a Soldering Iron and some steady hands, but the fix was worth it! Don’t forget to transfer the microphone seal from your old case to the new one, and use A LOT of glue to get the back sealed back up!
Bonjour, j’ai trouvé plusieurs sites qui vendent des boutons.
https://www.shapeways.com/product/ANHBW4...
https://www.shapeways.com/product/4Q27VC...
https://favouritehumandesign.com/product...
I have resolved with this:
"2 Smart Watch custodia originale in ePaper con pulsanti laterali in gomma e pannello in vetro Gorilla Corning - AliExpress
Frank Scheers crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 65
crwdns2942667:0crwdne2942667:0 7,136
