Where to get Adhesive Strips Replacement
Hey everyone. Where can I buy replacement Adhesive strips for the Battery of my Late 2013 Macbook Pro? I see there is a battery replacement kit. But I do not need a new battery. Just the adhesive. Can anyone help? Thanks
Can you just use double sided tap will that work?
Hey Sally. You can certainly try it out. Just make sure it is strong enough to hold things in place.
Use some 3M Extreme mounting tape or Scotch. https://www.walmart.com/ip/Scotch-Extrem...
Thank you for the reply. Is this thin enough?
The tape is a little thick but I think there is enough room for it. Test out by placing a piece on the top of the existing battery on either end and close it up and see if it hold the lower cover off
I will give it a go this weekend. Thank you again.
Did this work for you?
Yes it did. Thank you very much! :-)
Will that tape make the battery hard to remove?
KeithMelara crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 4,138
