i think thermal paste , wont do anything unless you have some kind of heatsink in contact with chips(that’s what oldturkey said above). is impossible in other words.
personally , i am waiting for some thermal pads to arrive (just ordered some), so i can use them between the small gap of the board and the back of my phone (iphone 7 plus)
i am getting so much thermal throttle , even in some light games.antutu report 120.000 points without any modification, if i cool the device with some fresh water on the back or some ice + water on my hand i get 195.000++ points , thats crazy.
i have cleaned the phone from inside , with ultrasonic cleaner filled with isopropyl alchocol (case - board) but still no better results.
i will try to fit those pads (0.2 and 0.3mm thickness) into that phone and i ll report back in some days.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
crwdns2942205:01crwdne2942205:0
I don't know if you still needed an answer but here you go, just recently I Applied some Thermal Paste on my iPhone 7 Plus with 79% Battery Health it's a simple task if you know how to Remove the Screen
1. I Remove the Screen and then Unplug Battery and Screen Flexible from the Logic Board
FYI Apple Is Using a Thin Cooper Above the phone's Processor and then with some Thin Graphite.
2. I Gently Pulled the Graphite Up but don't completely Remove Them, then you should be able see The Thin Cooper then you should Applied the Thermal Paste on the Cooper just a tiny bit then spread it until you cover at least 80% of the Cooper then Gently close the Graphite again and use your finger to try to stick it back again from the edge to edge if the Graphite is secured then you add more Thermal Paste on the Graphite this time add a bit more then Spread It bit by bit until you nearly covered all the Graphite and just like that you just Applied you Thermal Paste from there you can installed back all the Metal Shield.
crwdns2934271:0crwdnd2934271:0 Mr,No Body crwdne2934271:0
