Extreme water damage on desktop pc.
My older computer (used as a file server) was next to my washer that was leaking. Its a little room. barley enough for that all. I had the computer laying mobo down. There was a big leak that was spewing water "Conveniently" right into the back. The board has massive spots of blue everywhere. Need to get this system running asap. Thanks!
@e_ah ahhh water damage....
need to take everything out...... take pics.... on it
any configuration on HDD ? like RAID or just standalone?
I guess right now, remove the hdd first. check for any water marks / corrosion , etc.
if all is good, and ensure there is no liquid, you will need to hook on another working system to recover your files, providing is standalone.
crwdns2944067:010crwdne2944067:0:
It is RAID. 3 2TB WD hdd's. Thankfully the hdd are above the water line. There is a few blue spots around densely populated areas. Also keep in mind this is soapy water too. The case is pretty slippery. I have alredy removed all components and cleaned them in alcohol. Im going to let those sit overnight. The psu is rusty inside so thats going in the bin. I will update you in the am.
The alcohol got rid of the blue but not the rust on the screws and case. Its it time for a new computer do you think this is salvageable?
what RAID configuration did you set for your drives? i guess now your data is the concern now, but it is good to have a new system ready.
I used Raid 0
and to check if your RAID configuration is done on the mainboard or you have another RAID card to manage those drives?
recovering RAID 0 drives can be tricky, due to different controllers, and configuration, do proceed with caution, i would recommend you to label the drives and which sata ports is being connected to the SATA ports on the previous mainboard.
some good read,
https://ask.metafilter.com/126337/How-to...
i dun go for RAID 0 due to no fault tolerance.
normally the systems that was configures is raid 1
and another hdd to use as a back up .... e.g. using acronis, if windows.
or even better, backup to NAS
https://www.easeus.com/resource/raid-rec...
crwdns2934275:05crwdne2934275:0
Ethan Leroux crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 309
