Small media streaming device that plugs directly into your TV's HDMI port. Originally released by Amazon in November 2014. The latest version comes with a voice-activated remote.
power cable wont go into the fire stick
Got 2 fire sticks power cable wont go into the 1st one but goes into the second one looked in both ports and 1st port looks bent downwards
Any idea to fix this
My fire stick was showing no signal so I took the cover off and the cable that goes into the stick the port inside has broken away from the main board is their any way to fix
If I were you I would disassemble the device and gently try to bend the port back upwards with some pliers or tweezers, see if you can get it to fit with the case back on. Good luck, hope that helped!
Sam crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 3,175
