@michellerichins you did not tell us what model your Samsung actually is. This will be important information to have to see if we can assist you with your repair. The 5 blinks are not very informative since this is simply a general no power /signal fault. It is important to check the caps (specially on a Samsung) but even failed caps may look normal. You will have to check the connector and test points for the proper voltages. The clicking you hear is most likely one of the relays that turn the TV off to protect it's circuits. Since you removed the back, post some images of all of your boards as well as the total layout so we can see what you see. Use this guide Adding images to an existing question for that. Once you do that, unplug the T-con board. This is the other major board connected to the main board. See if that changes anything. Also, check the fuses on the T-con board, power board and main board for continuity. You will need a multimeter to check this TV.
The fuse on the T-con board is partially covered by the large heatsink.
Of course if you are more comfortable with exchanging the board itself, that is a possibility as well. You can get that from places like this and many others.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
Hi there I have a similar issue I think with my tv... model number UN55D6500VFXZC ... standby light is on and working, try to turn tv on and standby light flashed 5 or so times and the I hear a click.... it’s like it’s stuck in this cycle of the standby light flashing and the faint click... unplug tv (which is plugged into a surge protected power bar) and tv will actually continue to have the standby light and faint clicking will continue for about 30 seconds to a min even when completely unplugged. Anyone have any suggestions???
crwdns2934271:0crwdnd2934271:0 Jennifer Anderson crwdne2934271:0
Hi my samsung uhdtv 50 7 series nu7090 power button red light is blinking and won't come on
crwdns2934271:0crwdnd2934271:0 andyhintzen98 crwdne2934271:0
The power supply unit needed replacement (used amazon) after seeing nothing on the screen and just a red flashing light on the indicator. Worked Great
crwdns2934271:0crwdnd2934271:0 jack Tide crwdne2934271:0
