Repair guides and support for the eighth generation of Ford F-Series trucks: the F-150, F-250, F-350, and F-Super Duty.
Why is my 5 speed 1993 xlt stuck in gear
Why is my f-150 5 speed xlt
hung in gear
1993 f150 stuck in gear
Clutch is ok, slave cyl. was leaking down got that fixed, 165000 mi. think my nephew crammed it in gear while cyl. was weak. I am feeling like the shifter has jumped track or broke. I think I can take shifter up from floor to see. My question is can I fix it that way or do I have to take trans. out of the truck. Thanks for responding.
Johnny Johnson you definitely can remove the shifter with the transmission remaining. Actually you will have to remove the shifter to drop the tranny. Here are the instructions from 1980-199 Ford Pick-Ups. Typical Haynes, kind of crummy but hope it'll help you out.
Since yours is a 5-speed and you did not mention anything about OD, I added the manual for the Mazda S5-42 ZF Transmission Mazda_Ford-ZF-S5-42-Transmissi.pdf
Thank you very much I will try this , I will need this.
Johnny Johnson you are welcome. BTW great truck and those are real workhorses. Keep it going....
Johnny Johnson crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 4,098
