Hi @ martyhoh,
You don't state the model number of your TV but have you tried operating/releasing the Volume Up button on the TV itself (if it has one) to see if this clears the volume level indicator.
It may be a faulty Volume Up button that is the cause of the problem.
If this doesn't work, try disconnecting the power from the TV and then removing the back off the TV and disconnecting the button "board" cable from the mainboard. Then reconnect the power to the TV and check if this prevents the problem from occurring.
Be careful when working in the back of the TV. Try not to touch anything that you shouldn’t and do not just pull the button board cable connector out. Inspect it to see how it releases from the connector on the mainboard. Also don’t pull it by the wires as you may pull them out of the connector (if it is a connector type arrangement). pull it by the plug instead. You don’t want to cause more problems. ;-)
If the button board is the cause of the problem, you still should be able to use the remote control to control the TV, until you get a replacement button board
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
4
crwdns2944067:031crwdne2944067:0
I have an Insignia TV thats been doing this sporadically for about 2 months,but whatever is “telling “ the TV to do this is a big mystery.Tonight I not only rebooted the cable but also unplugged the TV and left it off for a while.When i reattached the plug and turned it on it was EXACTLY the same,and still had the Volume level indicator still stuck on screen.Why would any TV have such a stubborn control,unless it's some kind of safety feature? It is very perplexing and frustrating.Hard to believe after all these years so many folks are dealing with such an annoying yet hard to fix problem…
crwdns2934271:0crwdnd2934271:0 martyhoh crwdne2934271:0
Please help, this is really frustating
crwdns2934271:0crwdnd2934271:0 galbert einstein crwdne2934271:0
1-19-2019 We’ve been having the same sort of problem but not only does volume go up BUT the tv turns itself on during the night and volume goes to 100. I’ve changed batteries, rebooted, unplugged, gone back to original settings and then reinstalled everything. I don’t know what else to do. I called the cable company but they say it’s the tv. I’ve called the LG tv company and they run tests and say tv is fine. TV is less than a year old.
crwdns2934271:0crwdnd2934271:0 ohlmeyer6 crwdne2934271:0
Hi @ohlmeyer6,
What is the model number of the LG TV?
If it is connected to the internet, try disconnecting the internet and check if the problems stops.
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
Ohlmeyer6 I have exactly the same problem and my TV is also less than a year old. I’m not sure how to fix it.
crwdns2934271:0crwdnd2934271:0 Tara crwdne2934271:0
crwdns2934275:026crwdne2934275:0
