Is it possible to replace lenovo yoga 520 keyboard?
The keys on the keyboard are sticky and stuck. I spilled a drink on it. Is it possible to repair or replace the key board in India?
I would appreciate your response.
Sadly the keyboards not your only issue. Electronics Water Damage
Thank you for your reply. Would Lenovo help me with keyboard repair or replacement?
most likely you would have to pay for it.
Hi @pranjali ,
First do not turn on your laptop
Here is a link to the service manual. Go to p.33 to find the pre-requisite steps and then the procedure to remove the battery pack from the laptop.
Once the battery has been disconnected and removed, use the manual to dis assemble the laptop and then follow the guide provided in the above answer to thoroughly clean all the liquid and possible corrosion away using IPA90%+ (Isopropyl Alcohol - available at most pharmacies)
Once you are sure that it is totally clean as the keyboard is part of the upper case, on p.66 you'll find the part numbers for it. The part number should also be stamped on the underside of the upper case.
You may have to search online or contact Lenovo to get a replacement part.
Hopefully there has not been too much damage and that you will be able to get it working again. You can only try.
I just replaced the keyboard on my Lenovo, be sure to get all the part numbers on the bottom of the keyboard, if you have your local language on your keyboard also, be sure to give those numbers, if you want a plain English keyboard, you can save a little money with the generic replacement model like I did.
Hi all, I have replaced my keyboard, but when removing the old one, there were quite a number of plastic pins that secured the keyboard in place which had to be broken off (per the youtube advice) - the bit that I'm missing though is how do you now secure the keyboard to the top of the case - my keyboard is in and working, but the metal case around the keys is higher than the keys themselves!
crwdns2942667:0crwdne2942667:0 3,657
crwdns2934271:0crwdnd2934271:0 Pranjali crwdne2934271:0
YOGA 520 how to Replacement Keybord ?
crwdns2934271:0crwdnd2934271:0 teerterenena crwdne2934271:0
