The Honda Fit, also marketed as the Honda Jazz, is a five-door, front-engine, front-wheel drive B-segment subcompact car manufactured and marketed by Honda since 2001 and now in its third generation. Marketed worldwide and manufactured at ten plants in eight countries, sales reached almost 5 million by mid-2013.
Windscreen washer not pumping but rear window does
I have cleared the lines with compressed air and found no blockages. The rear window washer works fine. I would have thought there is only one pump. Is there 2, or do I have a faulty switch at the steering column?
There is usually only one washer bottle and two pumps. Often it is your rear that stops working due to lack of use. However in your case, I'd say yours has either burned out or just corroded. It will be underneath the washer bottle. What you can also check is your washer fuse.
One other thing, have someone work the front washer while you, with the bonnet (hood) open stand at the front and listen for the motor. If you don't hear it, suspect the motor. If you do hear it, suspect the lines from the washer bottle to a junction.
Peter King crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 25,879
