The Epson Artisan 1430 is a color inkjet photo printer.
removing cover artison 1430
I have a new Artison 1430, and want to remove the side panel for waste-ink adaption. On you-tube it shows tabs to be lifted, but my model has a smooth surface so obviously is a later model, and has no tabs showing. I'm afraid a repair manual may not be up-to-date. Anyone can help?
www.baharchap.com
OK, it's not very obvious, but the front panel on the right-hand side is just a cover plate` which pulls straight forward for removal. this exposes the 3 front tabs of the side panel, which are easilyprised free, and that allows the side panel to be worked upwards, disconnecting the remaining tabs, and removed.
Oh, I forgot: undo the centre and right-hand screws on the lower edge of the rear panel first, then prise the right-hand side of that rear panel to release the rear tabs of the side panel. This should be done first.
thanks charles. i wonder what other repair knowledge you have for the 1430, as i get really good photo prints with it. greg wheeler
can someone help me i have the same artisan 1430 printer, i tried to clean the printhead by dipping it in the windex maybe too submerged, i installed the printhead started to do cleaning at some point with the printhead almost all the way to the left went off and does not turn on anymore
Did you ever get this fixed? Mine won't turn on either.
George August crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 944
