2010 Jeep Liberty heater
Heat blows out on passenger side but not drivers side, cold air is blowing out of drivers side , doesn’t matter if it’s on defrost floor or dash all cold, got me stumped
Hi @sallad2420 ,
Check that the blend door actuator is operating OK or perhaps that the blend door itself is not stuck in the one position
Here is a video that may be of some help
Dallas it could also be the heater core has a small pin hole and needs to be replaced, same thing happened to my 2012 jeep liberty. It took me about 8 hours to pull the entire dash to replace it! are you getting any smell of anti freeze or oil film on the windows? If so it is potentially the issue. But first check the blenddoor actuate as mentioned. Hope this helps..
crwdns2936753:030crwdne2936753:0 58
crwdns2942667:0crwdne2942667:0 15,396
I have the same problem. Both heater hoses are hot so I assume the heater core is not blocked. The blend door actuator is moving as you turn the temperature dial. Can the actuator be moving and still not move the blend door?
crwdns2934271:0crwdnd2934271:0 l218 crwdne2934271:0
Hi @ l218,
Might be a bit of work but you should be able to move the blend door manually with the actuator removed, so you can see if it moves freely or not.
Then you could replace the actuator and try moving it by the actuator, in the normal manner, remove the actuator again and see if the blend door has shifted
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
flush out the heater core
crwdns2934271:0crwdnd2934271:0 buckmaster18232 crwdne2934271:0
