Skullcandy Crushers are packed with 2 drivers, the Sensation 55™, and the REX40™, delivering excellent sound quality and bass you can feel. The product was released on March 20, 2013 and goes by the model number S6SCFZ-072.
Bass not working well on lower volume
So i Just bought the skullcandy crusher wireless and am really happy with it, hut i seem to have this one porblem, whenever i listen music on lower volume, around 25 % the bass tends to Just turn off randomly. And will only work well with the bass slider on or above 50%. When i lower the bass it works for a little While and then it Just seems to turn off, and when i push it up halfway it Just turns on again. Again this is only on lower volume, on higher volume it workshop flawlesly.
crwdns2944067:08crwdne2944067:0
Hi,
Does it do this when you have the charger connected and switched on?
The Headphones dont work at While charging
I bought the headphones on 2018.02.20 and I have exactly the same problem. Were you able to fix it somehow?
I have the exact same problem, exactly this. Finally found someone with the same issue. Did you figure anything out?
I bought mine just 12 days ago and I have the same problem. My return/replace period just expired and now I must go through the hassle of claiming the warranty.
Is there any solution for this without claiming the warranty?
Every Skullcandy crusher wirless headphones have same issue …it need a minimum 50% of volume to activate this feature ..it required that much amount of energy from your phone if u connected with cable or if ur using via Bluetooth it perform same it need 40 to 50 % of volume to activate the
Hi,
Since you just got them and they are not working correctly, I suggest that you consult the manufacturer's warranty statement that should have come with the headphones as to what you have to do to make a claim for a manufacturer's warranty repair or replacement.
Skullcandy products are backed by a 2-year warranty.
If you can't find the warranty, here is a link
i found a different solution that has pc’s and laptops involved, after a few tests i found out that when i adjust the volume on pc, the volume overall of the skullcandy gets adjusted included the bass, make sure that after use of the pc you set the volume to 100, at least that was my solution, this also happened with some other devices.
Erik Bobeldijk crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 8,059
