Finding IMEI with FRP lock
hey guys.
Im looking to get the IMEI off of a board i got delivered. but its FRP locked. there are no identifiers on the board itself, and the dial code *#06# doesnt work because emergency caller wont allow it.
Am i missing something as to where that should be recorded? i know iphones have the "i" at the bottom corner, but samsung doesnt appear to have it.
crwdns2889612:0crwdne2889612:0 7
Does Download mode or Recovery mode show the IMEI?
Download Mode may show through adb?
crwdns2944067:07crwdne2944067:0:
neither of them show the imei. Im currently installing ADB to run through the last suggestion. while im doing that, do you have the command i would use to pull the IMEI through adb?
adb shell dumpsys iphonesubinfo
i get No device/Emulator found When i try to connect. i Have Google USB drivers installed in my SDK manager.
Removed comment.
crwdns2934275:02crwdne2934275:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
press volume up, power and home buttons all at same time. While holding down all 3 buttons the screen will start to flash and immediately let up on buttons and hit volume down and the IMEI, SKU and SN will appear on the screen.
Should the phone be off or on ?
if the battery cover is original it will have the imei at the bottom, hard to see i suggest some kind of led light to shine against it
Scott crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 50
crwdns2942667:0crwdne2942667:0 12,035
