Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
I got superglue on my camera lens
So I got superglue on my iPhone X rear camera.
I don’t think anything went inside the lens, but it’s extremely blurry when I try to take a picture.
Also, there is a tiny black hole on the lens, so I am wondering if there is a way to reach glue that went down there as well.
I’ve heard of using nail polish remover, but I am afraid of how that will react with the lens, possibly removing some sort of protective layer or something. I’m not entirely sure how the lens relates to the actual camera.
Is there a way to get rid of most, if not all, of the superglue without damaging the lens?
I believe that the glue was gorilla super glue.
Thanks
I got superglue on my camera lens on my macbook air and i used citrasolv with a cotton ball and the lens cleared up after a few scrubs.
crwdns2933315:07crwdne2933315:0
I don't know how you got superglue on your lens but I'm not one to ask.
And since it's about iPhone X, you should be good using nail polish remover or just soap or anything (I never used superglue before)
You can search on google how to clean superglue off things, iPhone 7's or higher usually are waterproof and/or have good durability, the risk of anything affecting the camera is small, unless you break it and THEN put superglue on it. However note that you might have issues with dust or filth because of the superglue so pay attention to that
And of course if that doesn't work go to the Apple Store, they got your back in case anyone screws things up
Yes, super glue on iPhone lens. Here is how it happens...
Take on a project designing a gown for a photo shoot called Ophelia. (Check out Sir John Everett Mallais painting of Ophelia in the water drowning)
Whilst making beaded gauntlet supports which must be glued every so often (with super glue mind you) and accidentally placing the phone on top of the plastic catch all dripping piece, thus resulting in super glue attached to the I phone camera. This is how it happened to me moments ago.
Id be careful since acetone could be very corrosive, I'd use some gloves and dampen a paper towel in acetone. You could use nail polish remover as well just be careful to not get it through the mic hole.
https://www.doityourself.com/stry/4-tips...
Use a cotton bud to put the solvent on. You can then be more precise with your application of the solvent.
my nail glue got on my computer camera
yea same tho but like how did you do it tho
Super glue is one thing nobody will ever love to mess with because of how stubborn it can be.
One should notice that getting rid of the super glue should be done with care.
Gently soak rubbing alcohol on the affected part for some minutes and gently remove the glue with something very sharp like a blade.
U can also use break fluid if available
  • How do I get crazy glue off of computers camera
Hmm well I usually get a cotton tip and put olive oil on it, it worked when I once got my phone stocked to my desk with superglue 💀 hope this kinda helps!
Red Fish crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 98
crwdns2942667:0crwdne2942667:0 12,792
