Released in 1999, successor to the original PowerMac G3, 300-450 MHz, 64 or 128 MB of RAM, 6 or 12 GB HDD
Can only get it to boot from disk
After a long, confusing fiasco trying to reinstall the OS on it, replacing cables, swapping out disk drives, amongst other things, I FINALLY got something other than the blinking question mark folder. (which was quite a feat for someone who knows nothing about mac's albeit a fair bit about pc's) Only problem is that I forgot that I had unplugged the HD trying to get it to boot at all. So I plugged the HD back in and all I get now is a blank white screen and no activity from the dvd drive. I tried reformatting one of my pc HD's with macdrive 8 and tried again but I get the same blank white screen. Any help, thoughts or suggestions would be very greatly appreciated, I've been on a mission trying to get my antique up and running and have come so far....I can feel I'm so close!! Please help???
crwdns2889612:0crwdne2889612:0 -1
Possible ID conflict. Look up the jumper setting on your hard drive by doing a search for it at the manufacturers web site. If using two hard drives set one to master and one to slave. With just one hard drive you can use cable select but I prefer setting it to master. Fix the hard drive first and then connect the optical drive. The optical drives also have jumper settings. Check the ribbon cable into the logic board as that sometimes gets pulled out some when working on the hard drives.
tried that, everything is set correctly
Boot up from your system installation disk by holding down the "C" key. Go to the second screen pull down menu to Utilities -> Disk Utility and format the drive. and give it one partition. If the drive is an old one I would select the "write zeros" option to map out any bad blocks. This takes a while but will eliminate future problems. Now install your system.
Cera crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 808
