Repair guides and support for a wide range of small engines.
crwdns2934591:0103crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Why does my toyota automatic not always engage kn reverse gear?
I have Toyota townace.for somevtime intermittently its not always engaged into reverse gear. Sounds like spinning perhaps. i rev so hard it only crawls.. its like no engaging. I have in this time prior had rear axle seal redone as it was not done right FRom prev owner work & oil pushed thru to brakes too and they needed replacing. Could this work? Area, have effect cause this? TranFluids look not too bad and levels are adequate... it is getting worse. I do also have a stretched accrlerator cable.. but didnt think this could have anything to do with reversing problem. ..??HELP PLEASE
Does it work in forward?
If it does, it may be that the shifter linkage is not adjusted correctly so that it's not actually shifting into reverse.
The brakes and throttle linkage are not related to what you describe.
crwdns2942205:01crwdne2942205:0:
it is necessary to check or adjust the steering clearance to be as accurate as possible. occasionally changing the oil and filter in the automatic transmission also helps.
Leisa Dawn crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 284
