Replace battery *and* lower case in MacBook 12" A1534 Early 2015?
My MacBook 12" Retina A1534 Early 2015 is showing the "service battery" warning in both the system controls as well as Coconut Battery. I am looking to replace it myself, however the repair guide on iFixit essentially involves dismantling the entire machine and leaving only the lower case assembly and battery.
Is there a way to remove the battery without stripping it down to the lower case assembly?
Also, is there adhesive holding the battery to the lower assembly? The repair guide did not provide any detail about removing the battery.
Thank you.
Hello Jason,
The battery is solidly glued to the bottom panel not the bottom chassis. Unfortunately to replace the battery you would need to use a bunch of adhesive remover and plastic cards to undo the battery. I would try to buy the battery attached to a bottom panel and follow the LCD/LB guide to disassemble the computer.
If you do decide to buy just the battery I would follow up to step 20 of the LCD guide and remove the Logic Board with the logic board guide. Then remove any other components before you start to go to town on the battery. Use only plastic tools, if you puncture the black battery casing it causes a chemical reaction and can start a fire.
Retina MacBook 2015 Display Assembly Replacement
Retina MacBook 2015 Logic Board Replacement
iFixit Adhesive Remover
MacBook 12" Retina (Early 2015) Battery
Battery Blocker
Plastic Cards
crwdns2886500:0Handy tool for opening devices, spreading thermal paste, and scraping. Same as Apple Tool Part# 922-7172crwdne2886500:0
crwdns2934075:0crwdne2934075:0
Plastic Cards
$2.99
crwdns2886500:0The battery blocker allows the battery in many devices to be disconnected without removing the logic board.crwdne2886500:0
Battery Blocker
$3.99
crwdns2886500:0Soften adhesive to make prying and separating electronics components easier.crwdne2886500:0
$19.99
crwdns2886500:0Replacement 4800 mAh battery for MacBook 12" Retina (Early 2015).crwdne2886500:0
$109.99
crwdns2886500:0Retina MacBook 2015 Logic Boardcrwdne2886500:0
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937803:0crwdne2937803:0
1 hour
crwdns2886500:0Retina MacBook 2015 Display Assemblycrwdne2886500:0
crwdns2937801:0crwdne2937801:0
2 - 3 hours
Jason S crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 5,539
