The HP LaserJet 1200 is a monochrome laser printer produced by Hewlett-Packard.
crwdns2934591:010crwdne2934591:0 crwdns2934593:0crwdne2934593:0
My faithful Laserjet 1200 printer will no longer print.
My printer was working perfectly. All of a sudden, when I try to print, the small green light on the upper left goes on for a few seconds, then reverts to yellow blinking. I have restarted it to no avail. I have checked to be sure that there is no paper stuck anywhere.
I love this printer. It has been my workhorse for many years. Can you please tell me what I should check or do? I feel like a good friend is in intensive care.
Thanks for your help,
Margo Smith
crwdns2942205:01crwdne2942205:0:
When was the last time you replaced the Laserjet 1200 maintenance kit?
This error contains lots of reasons. The first and easiest is to open the ink door and remove the cartridges and put them back in and close the door.
Replace any ink cartridge that feels or sounds empty.
Unplug all cords to the printer except the power cord. Turn it off and on then hold down the go button for 10 seconds. This will reset it to factory defauts.
My HP LaserJet 1200 print blank space what should I do please
There are 2 error codes - up here. First one - basic, and second code - for fatal errors to detect exact problem.
Here is link. It's translated to English page that can be useful for you.
https://translate.google.com/translate?h...
Here is link, that can be useful for you. It's translated to English explanation of error codes with possible required actions.
The HP 1200 Laser Printer does NOT have a power switch, only what I will call a reset button on the upper left of the cartridge door.  This button cycles when plugging the printer in to an outlet. It also is used to reset the cycle after a jam.
There must be an internal problem with the printer if all you get is a flashing amber light next to the reset button.
My 1200 just sits quietly on my desk with no motor operation, despite following all the commands on various help boards, as well as semi-disassembling the printer for a loose connection.
If someone has the solution, a response is appreciated. Meantime, old faithful goes into the closet.
Reg Miller
Margo Smith crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 5,547
