Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
iPhone worth repairing with extreme cracked screen?
Has shattered screen not sure about lcd? power turns on and off, home button works etc i think camera works also, what parts do I need to attempt repairs?? the screen does operate properly dude to major cracks and breakage. Just of course doesn't work sensitivity. thank you for any help and suggestion, ASAP would be greatly appreciated.
UPDATE BY @captainsnowball this is an iphone 5s not iphone 5c! only iphone 5s has touch id!
idk it was given to me so its an iphone 5s, it tuens on the home button works but the screen is so shattered i cannot get into setting for example without bouncing around and ending upu in my contacts for example, if someone could point me in the right direction as to what i need to fix this and is it worth fixing I would greatly appreciate it,
Hello, as the upper area is completely broken i would suggest to buy the full set which includes the front camera and the small parts there: iPhone 5s Screen
iPhone 5s Screen Replacement
You could also buy just the screen for a little less money, and transfer the stuff to your new screen.
crwdns2886500:0Replace a screen compatible with iPhone 5s. Includes all of the small parts pre-installed in the assembly, saving time and increasing the quality of your repair. 4 inch 640 x 1136 pixel LCD Display.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
iPhone 5s Screen
$34.99
I agree with this answer.
OP could probably get away with just replacing the screen but the front camera lens may be scratched
He doesnt have an iphone 5c only iphone 5s has touchid
@captainsnowball you are right, I'll edit it thank you!
the link Xacobe Cimadevila is 50$ ut i find some much cheaper like 20-30$ on ebay for example. Is there a difference in which I buy, i don't want some cheap knock off I decide to repair this which i am confident I can do on my own, but I have also gotten feed back that its not worth fixing and yes apparently it is a 5s not a 5c I apologize for that misinformation...but if its not worth fixing then ill just junk it, otherwise the 20-30$ display assembly is ok to get compared to the 50$ one?
If you are searching in eBay just find a provider with nice feedbacks, you can find the screen at half the price you will buy it in this website and should be a nice quality screen. If it's worth to fix it or not is up to you, as another person told you, it's not supported by Apple anymore, but you can extend a bit more its lifetime.
The display assembly is about $20-40USD.
https://www.ebay.com/sch/i.html?_from=R4...
Front camera is about $5
Here is the repair guide.
iPhone 5s Teardown
Since the display currently doesn't work on your phone, I don't know if there are any other hidden costs besides a possible front camera.
@avanteguarde he has touch id so he must have a iphone 5s, not 5c!
yes its a 5s sorry my bad
james here is a link to a full assembly https://www.ebay.co.uk/itm/For-iPhone-5S.... Follow this guide to replace the lcd just switch over the home button if you want to keep touch id. here is a link to the guide.
iPhone 5s Front Panel Assembly Replacement
@refectio this above any better
James Huntley crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 1,781
