How to remove Glass to clean dirt?
Need to remove glass to clean dirt from screen, as well as what is best to clean it with...Thanks
This guide is a bit more detailed on removing the panel. It is for an iMac, but the procedure should be pretty much the same.
Here's the tear down. This will show you how to get into it. There's a video also. Use a non-ammonia glass cleaner such as Sprayway, applied to a very soft cloth. Do not spray cleaner directly onto electronics.
I couldn't find that guide. I've voted to move your comment to an answer.
Andrew, if you'll form your link into an answer, I'll delete mine
crwdns2942667:0crwdne2942667:0 4,634
