The latest phone in the HTC One line, simply called the HTC 10, released in 2016.
Adhesive for the screen?
Which one is used in the video?
Not exactly sure what Eric is using here but I find 3M two sided tape works well in this application
Hope this helps
I just recently replaced battery and screen(after breaking screen during battery repair). I used double sided tape to hold the screen together. Anything on amazon would probably work, I prefer you get 1mm, 2mm, and 3mm width pack cause the 1-2mm works great for the side bezel while the 2-3mm works good for the top and bottom. Works great except for the lower part where the fingerprint scanner is. I can't get a precise measurement but it seems like the tape is 0.25mm thick, as in the height. This was too thin for the lower part. It would separate and I would see the light bleed out the sides, so I had to double up the tape to get the bottom to stick.
belokk crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 1,774
