Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
crwdns2934591:02690crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Phone not charging after battery and charging port change
Completed a battery change and charging port change but phone failed to charge. I placed a USB Detector between the power supply and the charging cord and it shows no load going to the phone. Also hooked a test cable at the battery connection and plugged in the phone. It confirmed that there is no charge going to the battery. Battery showed voltage on the meter. What is the best way to confirm if the new charging port is bad? Or if the IC USB chip is bad? Thank you
since you changed the battery and charge port and cant see any charge with the v/a meter i would say tristar could be the problem
Then the chip is the next step. I will follow-up afterwards. Thank you for your answer.
Was the phone charging before with the original port??? Check on the USB ampmeter first with the original port if it doesn't charge try it with the original battery and the original port if none work then it might be worth going for tristar
Bryan Solo crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 122
