A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
crwdns2934591:0216crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Need Replacement Coax Wifi Connector - Any place to buy?
Hi all,
after continues unplugging and plugging in (after various tests of the water daamged Macbook of my aunt) one of the Coax connectors for the wifi or Bluetooth antenna broke off and needs to be replaced now. Any idea where I can buy a replacement? I uploaded an image where I marked the said connector bellow:
I have no 100% size measurements but I think the size is 2.6mm lenght 2.6mm width and 1 ish mm height (used an rubbish ruler that I had laying around sorry).
There are certain names for these coax connectors to identify each one and not all have the same size I think, so any help on these to identify them would be helpfull. Thanks :-)
Sometimes if you cant find in a marketplace you can buy a "dead" motherboard. I usually keep some to be donor boards.
@israel Thanks for the suggestion but my heatgun is not strong enough to get these off of the board so I had to use the ghetto method and put a lot of solder onto my soldering iron to get it off the board.. So buying an donor board is useless because it will end up damaged anyways :( Hope you understand my concern..
I do, There are way of finding those connectors on component level stores such as digikey or Newark. At least I would start there.
Musti crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 78
