Released June 2014, identified by model number 15-d076nr
Laptop screen not working
I cleaned my laptop with Colin a general glass n stuffs cleaner liquid ...then on starting up it initially made a white screen on Windows 10 startup I unplugged the laptop and booted again same thing occurred ...the next time on it didn't even show the BIOS screen on startup ...but I can see the CPU lights blinking ...and a little spank on the screen
Hi!
You might have liquid-damaged the screen when you cleaned it.
Try shining a flashlight on to your screen to see if only the backlight is the problem. If you can barely see stuff on your screen it's only the backlight that needs to be replaced.
If however you can't see a thing on your screen even with a flashlight, plug it into an external monitor or TV, see if it detects your laptop as a source and shows content. If this works, replace the LCD panel.
Thanks fr the reply
Indranil crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 448
