Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
crwdns2934591:04994crwdne2934591:0 crwdns2934593:0crwdne2934593:0
iPhone is on but no screen
Two days ago for replace home button I unplugged screen connectors/sockets without power off phone and shows display. after I unplugged sockets, display/image went out and didn't come after plugged sockets. now there is no image on my phone. Phone and home button works but as I said no image on phone. What can I do now?
-itunes can find my phone,
-I shined flashlight on phone no icons or anything,
-Someone can call my phone,
crwdns2944067:04crwdne2944067:0
@mayer the apple genius!
@darkethereal as you get to know the guys you'll find out the different areas of expertise of each of us. Yes. mine is Apple but there are much better folks on Phones that I am. @refectio , @theimedic , @benjamen50, @israel are all better phone experts than I am
please help me guys :/
I believe @israel is correct on the Backlight issue. Power on your phone, look for the apple logo. If you do not see it, wait 2 - 3 minutes then push the power button to wake it and the home button after while shining the light at different angles. you should see something by trying the different screens to verify back light issue.
Hey there! haha Thanks Mayer, we all learn things everyday.
Savas, you can either have a no backlight issue or a not image issue. It sounds like no backlight is the issue even though you say shining a light doesn't help. It is hard sometimes to see image, usually when you are turning on the phone and the apple logo is shown the best time to identify backlight issue. If it is a non image issue most likely there are small square components on top of the LCD connector that could be knocked off easily. However backlight circuit can be affected when working on a phone with a plugged battery, so make sure to ALWAYS disconnect the battery first! I can look at it if you want to mail it in ;)
I am in Turkey, how can I contact with you?
Email me if you’d like! Email address is on my profile!
A common problem is long screw damage. This is on the shield that covers the display connectors, there is one long screw and if you put it into the wrong hole it will damage the traces inside the motherboard. It is common for the display to no longer work.
It could also be a blown filter that may have been shorted to ground when you opened the phone when powered up. This is a very small component soldered onto the motherboard.....
Either way if you want to get the phone back to life it will need a professional repairer that does micro soldering
crwdns2942205:01crwdne2942205:0:
mm I know all screw's place and all is in correct place. I will take phone to apple service but I wanna know what is the problem and I will tell them the problem
Savaş Demir crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 100
