The power input on laptop has come loose
The input jack bit on my lenovo g580 has come lose and now moves away when i try to connect it to the power lead, anyone have any idea of how to fix it back in place, it's attached to the usb ports on the side that are also loose.
I've tried bracing it with some plsatic and gluing it in place but it wasn't strong enough
Cheers
What glue did you use? It sounds like a piece of plastic holding the jack in place has got broken. You may find that 2-part epoxy resin will be more successful as yo can use the not only to stick with, but also to fill a void left by the broken plastic. But you'll have to reassemble the case before the epoxy goes rock solid as you may have to shave off any excess.
Joshua Clay-Dennis crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 186
