Why is my JBL making noise?
Does anyone know how to fix problem from this video: https://www.youtube.com/watch?v=5j9E8lN_...
i have the exact same problem, it is very anoying to play it half of the max volume...please help :(
I tried everything, to charge it, update it, with another device, when on full volume it plays normal for about 3 minutes and than it produces that sound and turns off and its not blown drivers because it sounds perfectly on max volume for 3 minutes and then the noise starts....please someone?
crwdns2944067:04crwdne2944067:0
Its happening to me also!
You find what to do about it?
Does your battery look too big for its spot? I mean, when I took my speaker to pieces, the plastic part that covers the battery seems to compress it , as if the battery was bigger than it should be. I can't put it back together anymore because of the battery, which is too big. It might be a stupid question but does someone know if a battery can get bigger when you take it into a plane?
my jbl flip 5 keeps turning up by itself plss help!!
Thank you so much.. it’s working 100% now. JBL CHARGE 4 working perfectly on max volume.
I had the same problem and I just replaced the battery. No more noises at all!
crwdns2947721:0crwdne2947721:0
crwdns2947633:0crwdne2947633:0
Run the battery till its completely dead . charge till its 100% then try it
Thanks for answer, I am going to try this
And did it work?
its working now. thank youuuu
that does not work for me
Thank you so much worked for me. JBL CHARGER 4 working perfectly now without the noice at max volume.
My speaker makes this weird noise as well when i increase the volume especially when a song has base and its battery dies quick, how can i fix it?
I have the same problem, if I play more than half volume my JBL starts cracklin. However, if I plug it in and play full blast, the cracklin is gone. I reckon this has something to do with the battery, but I don't know how to fix it. Maybe replacing the battery?
My JBL speaker sometimes made noises when the speaker was powered on, but with nothing being played. So I remembered a device I bought for my car when I was playing audiobooks thru the speaker system using a plug in the glove box. It is called a ‘Ground Loop Isolator’ (mine is made by Pyle) and when I plugged it into the JBL speaker input, then plugged the device into the computer, the noise disappeared. Got it on Amazon and it now costs $12.79 (October 2020).
Sava Andjelic crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 16,481
