The Toyota Celica is a sports car produced by Toyota between 1970 and 2006. The final generation was introduced in 1999 for the 2000 model year.
Cabin electrical problem in my 2002 toyota celica
After replacing the battery, the radio, power door locks and windows, daytime lights, break light, signal lights, windshield wipers dashboard lights stop working etc stop working. I've checked the small fuses and are all good. What did I mess up and how can I fix it.?
Hey Sam.
It's possible, I guess, that you may have shorted something out when changing the battery. Losing this array of functions suddenly isn't typical.
If it were me, I might replace the tail-light relay and see if this remedies some of the outages (several functions effected with this relay). If this turns out to be the case, you may then try to identify other relevant relays to test.
Also, just FYI, when checking fuses I’d recommend using a test light, rather than simply inspecting visually, as this also takes the integrity of contacts/pins into account.
Know this isn’t much help. Wish you luck.
did you wire it correctly , as well as check the wires for any wear
Check the ground cable for corrosion and proper connection. Sometimes the corrosion is hidden under the insulation.
Sam crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 557
