The Roomba 650 is a Fourth Generation robotic vacuum released by iRobot in August 2012. This device is hand-free and is programmed to clean our homes. With little manual operation needed, this robot have revolutionized house cleaning.
Error 5 iRobot roomba 650
I have replaced the battery with the new one and still after charging it says please charge the roomba
Error 5 indicates a battery problem
Try this link and see if this will help
https://homesupport.irobot.com/app/answe...
crwdns2947631:0crwdne2947631:0
xkubasj: The reason is that this charger has different parameters than the original one. Although the original power supply has nominal output voltage 22.5 V, the voltage drops to approx. 19.1V under 1A load. This third-party adaptor however holds nominal voltage 22.5V which leads to increased charging current about 3A. Roomba's charge controller than switches to fail-safe mode.
Here is a good step by step:
https://yoursmarthomeguide.com/smart-app...
Did you get genuine iRobot battery? Otherwise, suggest to check steps mentioned here (cleaning contacts, etc.): https://homesupport.irobot.com/app/answe...
@robotechy good answer but it has an identical link as the answer from a year ago. So yours does not add anything new to this as a solution. Maybe you can narrow it down and/or be more specific about the error itself
Interesting comments have a https://www.vacuumkoo.com/roomba-860-vs-... the different between the battery one has had this error message and the it look like iRobot mentioned regarding the type of battery used.
azornic crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 14,515
