Ethernet card not working
I am unable to connect to the internet via cable (wireless works) and I believe the issue is with the Ethernet card, but I may be wrong. I tried numerous cables (I even tried to use a cable on another computer and it worked, so the issue is not with my internet or the cable). The internet does not work with a cable. Any advise as to what this issue may be, or if the issue is the ethernet card, how I go about replacing it, would be greatly appreciated.
Amanda
+ for clear understandable question ;-)
The ethernet is built into the logic board. You can go with a USB to ethernet dongle or use an airport card. Installing an airport card is a five minute job. It uses a standard AirPort Extreme card. If you give the spped of your machine I can direct you to the installation guide.
crwdns2944067:08crwdne2944067:0:
Thanks for your help Mayer! The processor speed is 1.83 GHz. What do you mean by USB to ethernet dongle? I tried to connect to the internet via a USB cable but that didn't work either.
He means to buy one of these.
Here's how to install an airport card, and rab is correct on the dongle: iMac Intel 17" AirPort Extreme Replacement
Thanks guys for your help. One more question - which would you recommend?
Costs are about the same, airport gives you mobility, dongle is faster.
Amanda C crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 1,381
