internal microphone cable connector pinout
In my Imac the little cable is missing between the microphone and the 3-pin connector. The cables in the connector are: gray-white, brown-white, black. Can anybody help me witch 2 cables do I have to use to the internal microphone?
Thanks!
You can use an external microphone. You might want to check to see if it's just disconnected. See steps 6 & 7 of this guide: iMac Intel 17" Camera Board Replacement
That failing, I believe this is the cable you need: http://www.gainsaver.com/Catalog/Detail....
I have this cable what yout have linked, and I have the microphone. I just need the pinout the little cable between this cable and the microphone.
I haven't been able to find a pin out on the microphone, there just no call for it. I'd just wire it up and test it. I don't think there much of a chance of harming anything. I'd start with the black as ground.
Hi, I have the same issue with a used imac. Do you have understand the right wire pin out?
Thanks in advance! Gustavo
petilaci crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 1,575
