Hi Michael,
Just because the relay is good doesn't mean the fuel pump is good. In this vehicle, the fuel pump is located in the tank itself, and does not have an access point to get to it without dropping the fuel tank. There are plenty of videos online on how to change the fuel pump in your car, including one where the guy cut a small hole through the body work under the rear seat to make an access point to remove the fuel pump without dropping the tank. Not a pretty job, and not recommended, but did get the job done. It's up to you to decide how you want to go about the repair. Obviously, you want to be careful not to damage the fuel lines or the tank during removal, as it contains a flammable liquid! Good luck!
- Jasen
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
5
