GSM version of the fourth generation of iPad released November 2, 2012. Model Number A1459 / 16, 32, or 64 GB
Why is tape/glue strip so bad?
Why is tape/glue strip so bad. It doesn't stick even after cleaning with alcohol.
Alcohol typically ruins adhesive. Ifixit recommends replacing those strips:
iPad 4 GSM Adhesive Strips Replacement (Existing Panel)
iPad 3/4 Adhesive Strips
crwdns2886500:0Replace the custom cut adhesive strips holding the front panel to the rear case compatible with the 3rd or 4th generation iPad. Model #A1416, A1430, A1403, A1458, A1459, A1460.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$6.99
I would add you need to apply pressure in one direction around as you apply the cover glass and keep it under pressure for a good 12hrs to let cure. Here's a good vid of us checking out different methods: EP65 Conclusion to the iPad Sealing Workshop at the iFixit Unconfrence
kay-peter Jensen crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 112
