Repair and disassembly guides for the Compaq Presario CQ40.
Why is my laptop not turning on?
Whenever I switch off my laptop, it doesn't turn off, it just goes to a black lit screen (no I am not joking) and stays like that until the battery runs out. After that, it doesn't even turn on for days. It does switch on after staying Idle for a week or two but the problem always repeats when I turn it iff again.
P.S. It is very old but runs perfectly when it is on, the problem only occurs when I switch it off.
Hi,
What OS is installed in the laptop?
What happens if you hold the power button to force it to shutdown?
Amaan Shikoh this sounds like an issue with your OS as @jayeff is already hinting. You can check if there is a BIOS update for your computer or re-install your OS. In your command line type
shutdown -s -f
and see if that works.
Amaan Shikoh crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 498
