No volume control- headphones or dock
I can't control the volume output of my 1st gen Touch on firmware 3.3.1.
When I plug headphones in the volume slider doesn't appear, reading around I see this was a pretty common issue when people updated to 3.x so I ran a jailbreak and installed SBSettings and the volume slider widget - it doesn't control the volume, still stays at a constant level.
I plugged into the dock and have the same issue - no control over volume from the iPod.
So although I was initially thinking a headphone jack might need replaced I'm not so sure now that when docked it still has the same issue!
Any ideas?
crwdns2889612:0crwdne2889612:0 -1
Just realised you can't control the volume in a dock with the volume slider on any iPod - maybe it is tahat jack needing replaced!
I would definitely start with the headphone jack. It is solder on the logic board and is available here http://www.parts4ipods.com/epages/es1157... and here http://www.ipadpartsshop.com/product_inf... and the instructions for the logic board are here iPod Touch 1st Generation Logic Board Replacement Good Luck to you and let us know what worked. :-)
Replacing the jack indeed did work - I just removed the ribbon and soldered small jumper cables.
Congratulations, good job and inventive :-) Thanks for accepting my answer.
Neil crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 3,788
