The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
Why does my graphing screen keep saying "error: invalid dimension"?
I drew a circle one time, after that my graphing screen doesn't work anymore. I rely on the graphing screen a lot to check my work so if it doesn't work it's a problem for me.
for me is the same when I tried to graph an histogram, it says invalid dimension error and below 1Quit. How can I solve this?
Hi Clara,
The ERR:INVALID DIMENSION error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press y , and then select 4:PlotsOff.
You specified a list dimension as something other than an integer between 1 and 999.
You specified a matrix dimension as something other than an integer between 1 and 99.
You attempted to invert a matrix that is not square.
Clara Chen crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 89
crwdns2942667:0crwdne2942667:0 34,448
