Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
iPhone cant activate after reset
I really need help my iphone is locked but opened via gpp lte chip i hard reset my phone last last day and after that i cant activate my phone already it said sim not supported i tried various sims and chips nothing helps my ios version is ios 11.0.1 i downgraded it to 10.3.3 hoping for fix but no
crwdns2889612:0crwdne2889612:0 7
crwdns2944067:06crwdne2944067:0
no other way because apple change its server
That is my problem too! I tried various chips and different sims but still does't work. Does it mean i can no longer use my iphone?
Mikaela where you from ?
Same prob. Can i still use this phone? Or should i buy a new phone? :(
I hard reset my Iphone 6s too now it wont detect my sim card, but it was working on 11.2.1 :(
crwdns2933315:06crwdne2933315:0
If the phone is locked on ATT card . The ATT can unlock it for free if it is linked to an ATT card previously. If is on other carrier locked you can check if the carrier can unlock your phone to use it. If nothing work you can buy a carrier activation card from eBay and try to activate with this one.
u need to by a new GPP/LTE chip to activate again your iphone. because the GPP chip was blocked nowadays.
Check the list on the System Status page. If the box by iOS Device Activation isn't green, try to activate your iPhone later.
If asked to enter your password as you activate your iPhone, enter the password. (A password prompt means that Activation Lock might be enabled in Find My iPhone.)
Restart your iPhone.
If you're using a cellular data connection, connect to a reliable Wi-Fi network instead.
If you still can't activate, here's how to activate your iPhone through iTunes instead:
Make sure that you have the latest version of iTunes.
Check that your computer has an Internet connection.
Open iTunes on your computer. With the cable that came with your iPhone, connect your iPhone to your computer.
Wait while iTunes detects and activates your iPhone:
If iTunes shows, "Set up as New" or "Restore from Backup," it means that iTunes activated your iPhone.
If an error in iTunes says that the SIM card isn't compatible, contact your carrier.
How to activate my iPhone 5s sim not supported
Also me sim not supported need activate
my iPhone 6 plus have same issues like that so i solved by changing NFC ic.Now working well.Before doing that clearly see that there is searching shows or no service on network bar.
same case of them mine is 12.4.1 sim not valid what should i do !!!
Fixie crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 22,264
