Sit-on-top lawn mower. Zero-turn radius mower, 50" mower deck, hydro transmission.
Battery has power but no electrical components respond
Battery has power but no electrical comps responsive. Has new ignition switch and battery. Engine turns over when I jump across solenoid with wrench.
If you have to bypass the solenoid then odds are you need a new solenoid . If the electrical components are wired through the solenoid then nothing will work if the solenoid is fried . Replace the solenoid . Hope this helps
My hour meter won't even come on. Battery is good but no electricity going to anything
Mine is doing the same thing. What did you find?
@kerrycollins check your seat switch (11)for continuity when pressure is applied. Check your circuit breaker (24) to make sure it is engaged.
There is a 20amp fuse across from the battery check that I’ve had the same symptoms turns out that’s what it was.
Kerry collins crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 2,462
